1 - 5 of 5 Posts
· Registered
Hi there all, I am new to this forum. I have a GTE which is linked to a Rolec 16amp charging point. I can't seem to get the defined charging timer on the car to work. Not good at techie stuff so please bear with me, I ticked the one which says charged ready to go by 7am as this should start charging about 5am. And I am on Agile Octopus, but the car just started charging straight away. The little light by the charging point looks right as it has a clock against it, but the opening badge has become dislodged from the locking device. Any thoughts ?
David Harnett
· Registered
Have you pressed the button with the clock/timer on it? It should flash green, rather than be a constant green if it is a timed set... (this is for the e-Golf - can't quite remember if it's the same for the GTE)
· Registered
Yes, as ChrisCross says, check your (adjustable) minimum charge level in your settings.
There is a sliding scale you can set.
If your timer is set, as soon as you connect a charger it will immediately charge up to the set level, THEN STOP.
The remaining charge will commence to sync with your departure time.
1 - 5 of 5 Posts
