1 - 12 of 12 Posts
Hi guys
Planning a long-ish trip for the half term break.
I'm using Zap Map to search for potential "Rapid" charging points along my route.
I presume as a 2019 eGolf owner I can take advantage of all the CCS options, that Zap Map lists, i.e.
CCS 50kw, CCS 100kw, CCS 150kw, CCS 350kw, CCS 25kw - i.e. are there any of these I can't use if I stopped off to charge??
Thanks a lot
Bryan
Kia Soul EV 2020
Hi guys
Thanks a lot
Bryan
Combine that research with ABetterRoutePlanner and you should be set.
e-golf should be able to use all CCS chargers, with the max rate of 40 or 43kW.
Reactions: Bryski
2018 e-Golf
I advise you to filter out ecotricty. Unreliable
VW ID.3 Worst Edition
I wouldn’t put too much faith in Ionity either. If they work at all, it’ll be high 20’s charge rate wise, better than nothing but you can do better elsewhere.
I always filter for Instavolt first, and go from there.
2020 BMW i3S 120Ah BEV
Instavolt get a lot of love round here, and it's totally justified. Simple, reliable, quick.
I only have a Polar card, and they are pretty solid aren't they. I wish all the providers, whoever they are e.g. Ecotricity etc etc, would offer a debit card option too. The multiple subscriptions cards is ridiculous!
The government says they will all offer contactless before long. Instavolt already do, as do several others.
Discussion Starter #8
The law says they will all offer contactless before long. Instavolt already do, as do several others.
Thanks @mrdr_ev - what's the best way of finding out which providers concretely offer contactless at all their locations? I assume Instavolt offer at all locations. Is it a case of emailing each provider and saying, do you offer contactless?
Zapmap, which I use usually flags a location by provider e.g. Ecotricity, Polar etc, but not always sure it is showing whether it is ALSO a contactless debit/credit card option....
Cheers
I thought Zapmap showed payment methods for each charge point? I accept that this info may be patchy though because not all the networks report their locations and capabilities themselves, a lot of locations are in zap-map via user contributions. The auto-reported sites in Zap-Map show live availability data too, so you should be pretty confident their data will be accurate.
Kia Soul EV 2020
Should be available in the "Info" tab for all chargers on Zap-Map.
Kona64
on the desktop zap map I can see filters / payment / contactless
that option is just above the one saying free to use , which is a very helpful filer choice !!!
If you use WattsUp to plan a route then choose overview it shows which ones take contactless.
1 - 12 of 12 Posts
