Thanks, I will have to research what travel mode does, and what model year car it is on. My car is a 2015 GTEI think that as the beam cutoff is flat on the GTE LEDs, you don’t need to do anything.
There is a thing called Travel Mode accessed by the CAR > LIGHT > Travel Mode RHD Traffic, but I don’t think my old GTE had that, or the e-Golf.
Just found this, but they say it should not be used permanently.Thanks, I will have to research what travel mode does, and what model year car it is on. My car is a 2015 GTE
Find someone with OBDeleven, if you car is 2015 is a matter of 30 seconds to activate the "travel mode" if you don't have one as a default.Thanks, I will have to research what travel mode does, and what model year car it is on. My car is a 2015 GTE
Decided to buy some EU lamps as I will spend more time abroad.Find someone with OBDeleven, if you car is 2015 is a matter of 30 seconds to activate the "travel mode" if you don't have one as a default.
Thanks, I have just purchased 2017 7.5. For the price difference and the milage difference I just had too. Now i need to find out if the lights are the same as the previous 2015 7 models. Keeping the car abroad it might just be better me purchasing lhd light.. but i will give it a try 1st beforehand.Travel mode on the newer GTEs just seems to drop both lights by a smidgen, given the beam cutoff is flat across both headlights and there is no kick up on the left-hand side to illuminate the near side on a right-hand drive car.
As the beam pattern is the same on your 2015 model, you can achieve similar in a few seconds with an Allen key whilst parked opposite a wall or similar, just tweak the white adjustments on the top of each headlight. I’m still pretty sure that headlight beams with a flat cutoff and no kick up don’t need any adjustments anyway.
My 2019 Mk 7.5 e-Golf had the same lights as the newer GTEs I believe, they were a flat cutoff as well. Never checked whether it had travel mode either, but I don’t remember ever seeing it.Thanks, I have just purchased 2017 7.5. For the price difference and the milage difference I just had too. Now i need to find out if the lights are the same as the previous 2015 7 models. Keeping the car abroad it might just be better me purchasing lhd light.. but i will give it a try 1st beforehand.
My 2015 GTE (MY16) had travel mode under the light setting for driving on the RHS.Thanks, I have just purchased 2017 7.5. For the price difference and the milage difference I just had too. Now i need to find out if the lights are the same as the previous 2015 7 models. Keeping the car abroad it might just be better me purchasing lhd light.. but i will give it a try 1st beforehand.
