1 - 20 of 21 Posts
Anyone else having difficulty opening your charge port flap. Mine seemed to be stuck solid today, managed to open it after some time manipulating it. Seems the spring catch is not strong enough to push it out. Unfortunately there is nothing to grip to pull it open, had to resort to using a screwdriver to wedge it open. Not great for a 30k+ car!! I have implemented a temporary solution by sticking a bit of gorilla tape to inside of flap at the tip which sticks out when flap is closed. It works but looks naff, do you think Kia would come up with a fix?
2020 Corsa E
There's a silicon grease you can get as well. I use that on the Zoe hinge so it doesn't squeak.
It's also worth making sure all around the charge port door is clean as any crud will impede opening.
It is just ordinary wd40 any silicone spray will do. Open flap and just spray on each side of the long plastic hinge, then open and close flap a few times to spread the spray, nothing special.
Mine was getting a bit stiff as well, I mentioned it at the 10k service and they applied a little silicone grease to both sides of the hinge. It's been fine since, so if it happens again I'll just do the same.
Mine is stiff at the moment as well, getting quite hard to open at times. It thought the colder weather was to blame. I'll have to find the silcone grease, I'm sure I have some in the workshop but I haven't seen it recently.
I was in weather of about 20-30 F (-7 to 0 C) for the past week. I did not have any problem with my charge port. The only issue I had was that I was struggling to get above 65-70 Amp charging speed when using fast chargers rated at 100 Amps.
Off to Halfords to buy some
Sent from my Pixel 4 using Tapatalk
Interesting that's PTFE based not silicone.
I used Gt85 (or maybe 95) on mine last week.
Seems fine now.
Still fit the can in the car, I'll double check the ingredients when I get back to the car tonight
Sent using Tapatalk (I'm on my phone so sorry for any auto correct screwups)
I used silicone grease I had lying around off a previous plumbing job, which had worked a treat.
This is what I used:
My KIA dealer has fixed it by removing some of the flap. Grease only works temporary.
That's not the cause of the sticking. In the back if the hinge, about in line with the yellow triangle in your picture are two dimples. This is part of a mechanism designed to stop the flap from springing right open. Unfortunately it works too well. Use spray grease in the offending area and it's job done.
1 - 20 of 21 Posts
