Charge time
2339 Views 11 Replies 7 Participants Last post by  CorsaeGaz
Hi all
Newbie to the forum and first time EV owner .
purchased a Kia Niro 4+ on March 1st , love the car but slightly concerned about the charge time . I eventually went for a 7kw pod point charger as when researching there web site it shows a charge time of 9hr, my car takes over 20hrs depending on how low it is to get to 100% .
the display on my car shows 7kw when plugged in . Is this normal ,is the Pod-Point website wrong or am I missing something.
thanks for your help
1 - 12 of 12 Posts
Hi all
Why 100%? Do you need it every day?
Also, 20hr at 7kW is roughly 140kWh... That's some overcharging. You need to check your setup, your car should be charging at around 10% per hour when connected to a 7kW charger. Couple of things to consider:
  • it could be the charger;
  • it could be the car;
Test them separately to find out which.
Hi
thanks for the reply . My car was on 35% and started charging at 10 last night ,this morning still showing had 8 hr to go . This is only the second time I have charged it and both times the same
142010
See less See more
Hi
thanks for the reply . My car was on 35% and started charging at 10 last night ,this morning still showing had 8 hr to go . This is only the second time I have charged it and both times the same View attachment 142010
According to that screen:
  • you have a charging schedule on?
  • your car is connected/charging at 2.3kW? Which is 10A.
  • Are you sure you are not connected to your granny charger at the moment?
  • Are you sure you don't have a power limit set in the car/charger?
  • It matches exactly, so it is a setting somewhere.
Hi . I have the schedule set for off peak charging which is 10 - 7 on my tariff. When I checked at 7 and saw it wasn’t fully charged I manually set it going again on the app
Could you go to a local 7kW public charger for an hour and see if you get the same result?
Ok have some further updates . Tried a public 7kw charger for an hour ,as soon as I plugged it in the time to 100% halved . Plugged my charger back in at home and the display showed 3.1kw , left it on charge went back 30 min later unlocked my car and the display was showing 1.3kw . Turned the Pod-Point charger off at the wall to re set . Powered back up and plugged the car in . The display originally showed 2.4 kw then gradually creeped up to 7kw . Definitely something going on with the charger ,have emailed Pod-Point support .
Apologies for the very basic question, but have you refreshed the app? It doesn't update itself and will present out of date information.
Charging to 100% takes longer than you might expect because of the final balancing of the cells. The charge rate slows to a trickle right at the end....
Your schedule of 9 hours is enough for 63kWh at 7kW charge rate, so you should have reached 100% in that time. If that's not happening then, yes, something is wrong.
When it's charging the Niro reports the charge rate - you say it's reporting 7kW,is the most you can get from a single phase AC charge point, so that checks out. But I don't know if that's measured or just what's negotiated with the charge point. It could be there's a fault with the onboard charger, though I'd expect that to be picked up and reported as an error.
As a comparison, I plugged in my e-Niro yesterday (first time I'd used the home charger point) at 49% at 15:20, it was at 80% at 18:31.
See less See more
Hi all
From memory there is an internal switch inside the PodPoint that sets the charging rate. I suspect this has been set to 3Kw/h rather than the required 7Kw/h. You probably need the original installer to make a return visit as the switch requires the cover to be removed for access.
Reactions: 1
142016
See less See more
Have logged a support call with Pod-Point, thanks for your help 👍
Reactions: 2
My switches were set incorrectly when my podpoint was installed and was limited to 10A. Use the table above and check your switch positions. It takes 2 minutes to sort yourself.
1 - 12 of 12 Posts
