1 - 3 of 3 Posts
I understand you can charge the Ampera at 6A, 10A, 13A and 16A (please correct me if I'm wrong)
What are the charge times from "flat" for the above ampages ?
I did try to search for the answer but was told:
"The following words in your search query were ignored because they are too common words: time charge."
The charging cable that comes with the car allows charging at 6A and 10A. The only other charging you might come across is 16A using a home charging pod or some public charging. Public charging at 16A requires the purchase of a different cable... a Type 1 to Type 2 cable at about £250. Most Ampera owners I suspect won't bother with that cable as charging will mostly be done overnight at home.
The battery takes about 12kWh from empty so charging times are approximately:
6A = 1380W so charging time would be approx 9:00hrs
10A = 2300W so charging time would be approx 6:00hrs
16A = 3680W so charging time would be approx 4:00hrs
Assumes empty at start of charge and mains voltage of 230V.
The search on this forum software will not allow certain common words. Sorry about that :oops:
Paul C
Perhaps us owners could maintain an Ampera FAQ to cover questions like this?
Paul R
1 - 3 of 3 Posts
