1 - 7 of 7 Posts
I got a chargedev install, everything has been great . But now we changed the router and need to connect the charger and I cannot find out how to do it, there absolutely no info about this, on chargedv site or kaluza, or in the kaluza app. Does anyone know the process?
@Mike Schooling will point you in the right direction. Presumably the issue is that you changed your password at the same time.
Hi.
@dk6780 thanks for the tag.
@str8g8 my company designed and manufactured your charger. I assume your unit is hard wired so it should just be a case of plugging the ethernet cable back in.
Your installer may have chosen to use powerline adaptors so make sure that that is still present.
If your still struggling perhaps you could share a picture of the router/any equipment?
Do you have a copy if the user manual?
Hope this helps,
Mike
Hi, thanks for the reply, I completely forgot it was actually a wired connection, assumed it was all wireless, doh! So I reconnected the ethernet cable... and still nothing, the charger is still offline according to kaluza app?
Thanks all working again now, for future reference, I had to turn the fuse switch off and on to reset the charger.
Great, glad its worked.
FYI if the unit doesn't see a network connection straight away it waits a set amount of time, if it still doesn't see a connection then it increases the wait period until it tries again. This is to avoid racking up data fees or clogging up a network.
Power cycling at the breaker is a good way of resetting the wait time and forcing it to connect
Sent from my SM-N976B using Tapatalk
Glad it's fixed. I'd forgotten that Mike had opted for a hard wired connection rather than the more usual (and painful) WiFi connection.
Good also to see that the normal IT advice of turning it on and off again worked. :rolleyes:
1 - 7 of 7 Posts
