Don't get a 16A (3.3 kW) EVSE unless there's some strong electrical reason why your house can't take it. 32A ones are (or should be!) only a little more cost, and more & more EVs now are coming with 7 kW domestic charging as the standard. The Ev will take what it wants, up to the max the EVSE offers. You can't damage a 16A-capable EV by plugging it into a 32A EVSE with a 32A cable connecting them. Going for 32A cable & EVSE future-proofs you as much as is possible for most of us. Domestic EVSEs are'n going to get much more powerful than that, for ages yet! We can forget about 3-phase 11 or 22 kW exotic stuff as hardly any houses have 3-phase her ein UK.
As far as make of EVSE's concerned, I'm tending to like the easily repairable dumb ones more & more. There are only 3 interesting things inside my Rolec; ECU (brains controller), RCBO, and Contactor, these last 2 are industry standard things you can get from local electrical outlet. And the ECU (Rolec brand) can be swapped for a Viridian Mainpine one for £80. The Rolec RCBOs are generally reckoned to be cr*p and have given the brand a bad name, so many of us are ditching then in the trash-can & fitting a £25 Garo replacement which is a quality item. The Contactor seems to be lasting ok (but cost about £65 if needing replacing). So these are repairable by any electrician for modest cost of parts.
I've been in touch with someone who has a broken Pod Point Solo; his builder jiggled the cables into it, it "made a funny crackling noise" and died. He took the top off and asked here for help. Builder had knocked a couple of components off the Circuit Board, a Pod Point custom item of course; I replaced them carefully, but the board was still dead. Pod Point are quoting him over £400 quid to repair it! There isn't any such circuit board inside the Rolec. Viridian themselves sell EVSEs, so they would also be on my list to look at. See
ecoHarmony .
I think there's a lot of rip-off pricing going on here; I can't see any justification for prices much above £350 tbh for these things, uness they're
really fancy. Someone here has just made their "dumb" EVSE "smart" by wiring in a very low-cost remote-controlled switch, again this is the kind of modification that can be done by any electrician given the bits and instructions. Would be good to see some of these really simple improvements made available as a kit-of-parts, or even just a shopping list of bits plus photos & docs to show us how to fit these. I'm intending to do my own solar panel sensing from my Rolec, now I have an EV that can benefit from this.
