1 - 13 of 13 Posts
Yesterday I tried to charge in one of the Source London stations, I plug my cable on my eNiro try to charge but it couldn't connect to the Source London system, so I unplugged closed door and move the car forward 5 meters to the next station. And what is my surprise when the charger door didn't open!
I have tried to turn on off the car a few times, check that all doors are unlocked by pressing the keyring open button multiple times, and even tried the emergency charger release, but nothing of this seems to have worked. My charger door still stuck.
Have anyone else experienced the same? Any trick I can try our do I need to take it to the dealer?
I was just wondering what would happen if this occurs in the middle of a long road trip!
I've seen a coke of people on here saying they had to pry the door open with a credit card.
Sent using Tapatalk (I'm on my phone so sorry for any auto correct screwups)
Thanks Grant may have a go with that. Did a quick search but couldn't find any similar questions.
Yes, it's a common problem. Give it an initial push to release the catch and then prise it open with a credit card type thing (I used to use my Polar card). Get it to the dealer when you can, they managed to free up mine.
Charge port flap
Charge port flap
Bingo! "Flap" was the keyword.
Thanks again Grant! I will give it a go tonight.
Thanks David will try with my "Source London" card ;)
Kia e-Niro 3 Slinky Silver, Renault Zoe R135GT
In the Nirio PHEV there is an orange release cable in the engine compartment that enables you to release the cable/open flap. Not sure in the BEV though
But this is not really the answer. If you look in the back of the hinge you'll see a couple of dimples an inch or two in from the face of the flap. These are part of a mechanism designed (??) to stop the flap from flicking right open, just ajar. If you use some spray grease in this area and work the flap a bit, it opens as it should again. WD40 might do the trick too but grease should last longer. Ours still pops open properly several weeks on.
This is a known problem, if you take it to dealers they will do a fix. Had same issue with mine, used wd40 which worked for a while, first service mentioned to dealer they said it's ok a known issue and have a fix. Looks like they shaved the hinge a bit, opened ok ever since.
Discussion Starter #12
Thanks Richard, seems to behave after I open it yesterday but I will add some grease to it to avoid further problems
Discussion Starter #13
Thanks Spark, I will mention next time I go to the dealer. Cannot be bothered to go just for this when there is a work around ?
1 - 13 of 13 Posts
