1 - 6 of 6 Posts
Discussion Starter · #2 ·
I did not think this was possible. My only guess is that because of the lower voltage the car can accept higher ampage as the incoming kWh is 7.69, below the 7.7 max.
Looks like an error in the UI. Car has reported "8kw" from my 7.6kw EO Mini Pro on several occasions... 8kW = (32A x 250V) / 1000
My car regularly shows charging at 12kW, with 3 phase 16A and 251v... never seen it over on Amps though, did for a while think of getting the second charger enabled for 24kW charging at work :)
Then thought better of it as they wanted £1200!
I also thought the 32A was a hard stop at the charger end, which seem odd, unless it is 32.500001A or similar
1 - 6 of 6 Posts
