1 - 3 of 3 Posts
Thinking of buying a 2013 Smart ED with the optional 22Kw on-board charger. My question is, although Smart replace the standard 3.6kW single phase cable with a 3-phase 22kW one, is the higher spec cable backwards compatible with the slower charging speeds? Put another way, will a 22kW 3-phase Mode-3 Type-2 cable connect with a 3.6/7.2kW charging supply or do I need different cables for each speed? Thanks if you have any experience to help.
1 - 3 of 3 Posts
