Hi all
So I am picking up my SR+ this Friday and very excited too! I'm currently trying to figure out my charging solution, which is quite limited. My situation is as follows:
1. My allocated car parking space is not outside my property, and it is too far away (about 60m) to run a cable across the road to get to the car
2. Because of this, the freeholder of the whole estate will not grant me the right to install a charger at the property, because we are technically not allowed to park outside (although in reality, this is fine for guests or overnight parking). As such, I will not be able to install a type 2 charger and will be limited to using only a 3-pin plug. This isn't actually a big issue for me, because I do a small mileage and charging overnight a few times a week should be sufficient. I also live close to two superchargers (within 10 minutes drive), and many public chargers.
3. My plan was to park directly outside the property to charge and to run the cable through our letterbox to connect to the socket. I'll of course use a heavy-duty surge breaker either way. Unfortunately, it doesn't look like a plug will fit through, so this isn't possible either. Alternatively, I can run a standard cable through a window instead and then put the window in a locked position but slightly open (this provides just enough room for the cable to fit and not be compromised, but little else!).
Clearly none of these options are ideal, so I thought I'd see if anybody else has any other suggestions or ways I could potentially do this? Just to reiterate, only using the 3-pin plug will be entirely sufficient for my usage. When the car is not being charged, it will spend the rest of the timing in the allocated space. It is not possible to install a charging point at the space either!
GRR!!
GRR!!
