1 - 1 of 1 Posts
Hi guys,
Just a bit of info, like most reviews I have found the front plastic flap where the charger plugs in to be flimsy, today on closing the flap it stuck not closed but not open sort of jammed about 20mm from closed, I tried pushing a screwdriver in to release it but no luck, so decided to leave it and take back to the dealership, so got into the car and switched ignition on and got the warning “front flap open” went back to the flap and found it had re set, the gizmo now turned the widget that had in turn rotated the grimble and it was back to normal,
So if this should happen to you turn on the ignition before anything else
1 - 1 of 1 Posts
