I got really excited until somebody said "BP Pulse". So what % of the devices will work do you think?This is "The NEC". At car park East 3, to be precise.
Sadly, it seems they'll be using BP Pulse chargers.
Exactly! On the other hand, the rapids are apparently going to be Alpitronic units, so they might have an uptime measured in days rather than hours.I got really excited until somebody said "BP Pulse". So what % of the devices will work do you think?
I think that's a good thing, right? With appropriate signage, should prevent accidental blocking of rapids by those charging on AC all day? But note the indicative lane marking "fast charge" pointing towards the rapid chargers, rather than the AC charging, which are presumably 7kW "fast" chargers...It seems that there will be no direct access between the AC chargers (for NEC visitors only) and the rapids (for people passing through).
Super Mega Ultra Rapid (+)Mega ultra rapid?![]()
I do agree in principle, but it gets tricky when the max output can depend on the voltage system of the car, and also can vary if it’s a chargepoint with distributed power with other cars already charging.IMHO better to simplify to some terms which mean what they say:
AC7, AC11, AC22, AC43
DC50, DC60, DC100, DC150 etc
I hope Zap-Map will modify these to CCS from Tesla CCS so they show up in filters.Looks like the pilot for Tesla opening UK superchargers to the rest of us has begun!
It’s official: Tesla opens up UK Supercharger network to non-Tesla drivers | Electrifying
For the first time ever in the UK, non-Tesla drivers will have access to the US brand’s coveted high-power Superchargers | Read more on Electrifying.comwww.electrifying.com
Available sites are as follows:-
- Adderstone NE70 7JU
- Aviemore PH22 1PN
- Dundee DD2 5JT
- Manchester Trafford Centre M17 8AA
- Flint Mountain CH6 5QG
- Aberystwyth SY23 3TL
- Banbury OX16 1LX
- Wyboston MK44 3AL
- Trumpington CB2 9FT
- Thetford IP24 3TP
- Wokingham RG41 5DG
- Uxbridge UB8 1QJ
- Thurrock RM20 2ZP
- Folkstone Eurotunnel Terminal CT18 8XX
It's a fair point, but I wan't trying to "boil the ocean" by including all the provisos!I do agree in principle, but it gets tricky when the max output can depend on the voltage system of the car, and also can vary if it’s a chargepoint with distributed power with other cars already charging.
As I understand it, the Kempower units dynamically adjust the display of vacant units to show what’s the max it could potentially deliver at that time, taking into account other cars already charging.
I don’t think you would have physical road signage that said “300 kW DC charging”, for these Alpitronic units for example, because at times that could be impossible to achieve, even if you did have a car that could readily accept it.
Maybe the road marking should say “300 kW charging (provided your car’s battery can take it and provided you don’t have to share a unit)”
I particularly like that (mains rather than AC) - by including the word "mains" - It certainly brings home the fact that you are just plugging into the mains, whether at home or elsewhere.AC chargers are just chargers - call them 'mains' chargers if you want.
How about "short-stay" chargers and "long-stay" chargers? It's not the rate that's the issue, and we all know lots of factors affect the rate we get, but the problem comes when we block a charger somebody else needs.All DC chargers should be called fast chargers. No point using ultra/rapid as that'll get obsolete eventually.
Well, they're not, are they? DC chargers are that: chargers. AC charge points are glorified electric plugs - the charger is in the car.All DC chargers should be called fast chargers. No point using ultra/rapid as that'll get obsolete eventually.
Rename them as follows:The whole naming needs a kick in the pants!
you know what people mean when they say that though. While technically correct I’m not sure calling them something different based on where the actual charging control hardware sits is that useful?Well, they're not, are they? DC chargers are that: chargers. AC charge points are glorified electric plugs - the charger is in the car.
I agree - it's not as bad as mixing up kW and kWh.you know what people mean when they say that though. While technically correct I’m not sure calling them something different based on where the actual charging control hardware sits is that useful?
