1 - 9 of 9 Posts
I have just purchased 2017 egolf but it won’t charge from my home 110v outlets. The green on button on charging cable comes on when I connect to outlet but when I attach to car after a few moments or sometimes minutes the on button flashes along with top red warning light, which apparently indicates outlet is not grounded properly. It is an old house but I haven’t had any other electrical problems. Any suggestions?
Thanks. I am reaching out to dealer and an electrician as well. Do you know whether all setting in echarging menu makes a difference? I have it at max but there are other amp settings from 13A down?
The current rate setting won't make any difference as the granny lead will only charge 10a max whatever you have the car set to.
Thanks. I have actually got it running off an outlet above washer and it worked fine if slow but it means running cable under door to garage. Now considering whether to get 240v dedicated outlet installed or run off 240v dryer outlet with splitter switch and 240v cable. Any thoughts? Looking for most affordable option
Is it dual voltage then if it works off 240v but not 110v? Obviously it will draw twice the current on 110v. What the regs re CV charging points are in the US are I don't know but they're quite strict in the UK and what you're suggesting will result in sharp intakes of breath!
1 - 9 of 9 Posts
