I spent an enjoyable 30 minutes yesterday trying to figure out how to get the charging timer on the car to play nicely with my Economy 7 times.
I am with Ecotricity on their 100% green Economy 7 tariff. In summer the cheap period is from 1am to 8am and in winter from midnight to 7am.
The charging timer on the Ampera is quiute flexible as it allows for many different scenarios with cheap rate electricity being one of them. However, the car allows for 3 rates... peak, mid-peak and off-peak. The challenge was to get the timer to only allow charging between 1am and 8am... this is how I did it.
I split the day into 3 sections and allocated them to these rates...
midnight to 1am - mid peak
1am to 8am - off-peak
8am to midnight - peak
I then set the timer to only charge in off-peak. It is possible to set it instead to charge during both mid-peak and off-peak if that is your choice.
The timer can also combine the off-peak charging with a departure time to make sure that your car is charged before you need to depart next day. I set my departure times for all days to 8am.
Last night the timer started charging at 1am and it finished at 4am so that works well.
When winter comes all I will need to do is reallocate the times so off-peak starts at midnight and ends at 7am with mid-peak 7am-8am and peak stays the same as 8am-midnight.
If anyone has any problems with this (let's face it, it isn't easy is it!) then just PM me
