1 - 20 of 81 Posts
Has anyone else had the door on their charging port stick?
It happens most of the time now... I will push the open button in the drivers door and get out to plug in only to find the door still closed. Using the keyfob I can hear the release but the door does not oopen. I have to apply a little pressure with my finger to ensure that when the catch releases it actually opens.
It seems that the spring isn't strong enough or it is sticking in some way.
Yet another thing to get the dealer to look at. :roll:
I tried holding the button pressed for longer and that worked for a few times but it doesn't open it at all now automatically.
I shall quirt something lubricating on it tomorrow and see it that helps :shock:
So why does we all get the same problem at the same time? is it weather related? I just had to apply oil to the hinge to this weekend also.
I'm now curious as to how the flap will stand up to icing, could be a PITA if you cant open the flap to charge when you get home because its frozen solid, or cant close it in the morning...
I feel like a proper Ampera owner now - I've just had my charge port door stick :)
So as regards lubrication, I've seen both 3-in-1 and WD40 suggested in this thread - WD40 sounds easier to get inside the holes. But can those who've done this indicate where exactly they sprayed the stuff to get the desired effect? You can't see an actual hinge as its behind trim.. I don't want to just spray it everywhere and hope.
Paul Churchley said:
I sprayed it with WD40 but as you say, it needs regular repeats.
You sprayed the same place as the previous poster Paul? i.e. the hole that the little locking tang comes out of on the right hand side?
Yes... and the hinge too... and the tang on the door.
OK thanks, its the first time its stuck today...
I was having the sticking door for a few weeks ever since the "rains came" along with temperature reduction.
I've used a little smear of petroleum jelly on the "tounge" (top and bottom) on the door and the recess in the aperture around and about the release pin. Have had no further problems and I also think this fix will last a bit longer than WD40.
Big Paul
Mine started happening within a couple of months. I have to apply slight pressure on the hinge side of the door when operating the solenoid. I have tried the slipperiest silicon stuff I know to no avail.
Happily the only thing on the list for the first service.
There are a number of discussions on the GM-Volt.com blog on this.
"White grease or any grease or oil based product will, as a previous poster pointed out, attract dirt, grime, etc...... the fix is silicone spray...... there are several close fitting parts on the door. Drag on any one or a combination can cause the door to stick. Spray, wipe, done, enjoy."
I'm in the larger group that has never had a problem, even with the charge door. Living in Colorado is perhaps the reason with low humidity.
Hope this helps.
Ross
1 - 20 of 81 Posts
