I've had an ev ( a renault zoe) since August. I use it to go to work every day (60mile round trip) and - in the middle of winter - obviously i'm charging it every night. From early on, there were times when it just randomly stopped charging after charging up about 20% more than when it started. I called Renault. They told me to talk to chargemaster. I did and chargemaster came out and found no fault - but changed the unit 'just in case'. The issue continued. Renault took the car to do checks - and I don't think did much except to say it charged fine on their charger. The issued continued. They took it away again. The courtesy Zoe they left with me mostly worked fine - then experienced the same problem - just once. Renault updated the software and tested it again - they found no issues and returned the car. The issue continues. It's happening most evenings now. If I get home at 6pm, I always nip out at 10pm to make sure it is charging. Mostly it isn't now - it displays 'on-going checks'. I unlock and open the door - it thinks for a bit then starts charging again and charges up overnight to 100%. If I get home at 10pm I can't do this, so wake up to a partially charged car which might not get me to and from work. All massively frustrating. I've gone back to chargemaster - but they are dragging their heels.
Anyone experienced this? Would be helpful to get some advice if you have. Thanks
