1 - 9 of 9 Posts
Hi all,
Apologies for the simple questions but this is my first jump into being a EV owner....
When charging the ZS, I can see there is a charge notification on the dash to tell me how much it's charging by but how do I get that to stay on or if that is not possible, turn it back on me to check?
Also if I was at a public charge point, would it be ok for me to charge while having the car powered on or is it better to keep it off?
Thanks in advance!
Press the brake pedal and the charge notification on the dash will appear for about 30 seconds each time. Also if you open the boot the charge will also be displayed.
You can charge with the car on.
MG EZS 2020
You can get the display to come on for a few moments if you open the boot (yes I know it's the 1st of April tomorrow, but this is not a joke), but you have to be quick to see or have better eyesight than me to see it from the boot.
Reactions: Ripspark
MG EZS 2020
I suppose if you have the latest BMS update you should be able to open the door to see it. (?????)
Reactions: Ripspark
Zoe Devotee
You can turn the car on when charging, press the start button twice (so the green led is on, not the orange). You can scroll through all the menus then, use the heated seats, heater, stereo etc too. It just won't drive (which you'd expect when plugged in). When you turn off it will show the charging screen again.
Or invest in OVMS and you can check the app at your hearts content while the car is charging.
Hi all,
Thanks in advance!
Manual says you can turn the car on to see this.
1 - 9 of 9 Posts
