This is a great find Mark. Where did you source a 63 amp cable?
Charging etiquette probably needed here, perhaps leave contact details In window and move if someone else turns up if you have enough range?
Yes Charging etiquette may well be needed .. in the future ?...
At the IKEA rapid in Southampton, I usually leave my number with the super helpful carpark attendant on the ground floor.
One of the most surprising things I've found about EV ownership is the number of times I've heard..
"that's the 1st time I've ever seen someone actually charging an electric car there".
and most folk have never seen (or heard of )a Tesla before, some dont know electric cars are in production !
The cable is a standard J1772 to Type2 with 3 mods:
1. Reduce length of Type 2 end by 14mm (cut square and accurately)
2. Check wire diameter, and if necessary Double up cable, (or add extra, 3 x 6mm square cables) to increase CSA to take 60A without any heat/voltage drop ... or... (at your own risk) accept the heat increase/slight voltage drop using 6mm CSA (32A) cables.
3. Change the sensing resistor in the Type2 Plug (to 100 ohm for 63A).
I intend to add a simple catch to augment the friction grip of the Type2 plug & socket - maybe a rubber sheath.
