1 - 5 of 5 Posts
If I understood the R90 version only has AC 22kW charging, so on a public charger I should be able to get somewhere near that but I want to get a charge point for my home, I have a 3-phase supply so does this mean that if I get a 22kW AC wallbox would I also get similar charge speeds? Or should I just get the 11kW wallbox?
Well an R90 will charge on 11kW in under 5 hours from zero. Do you need it to be three hours?
You didn't confirm what Amps you have available, which might be the limiting factor.
Not 100% sure about the amps, there is a 3-phase trip that says 40amps but there could be a main fuse in a box that I do not have access to, but I agree that it seems like a 11kW wallbox would be enough and easily give me a decent charge overnight.
1 - 5 of 5 Posts
