The highest I've ever seen the PTC heater in my car go is 3kW. While the car draws 6kW initially when the climate timer kicks in the rest of that is going to the battery to top it up slightly and this portion tapers off within a few minutes. After maybe 5-10 minutes the power level is down to around 1-2kW at least in mild weather, I haven't seen how it behaves in deep winter yet.
Interesting fact - when you do timed climate control or remote climate control the car does not use the heat pump to warm the car. (!) It only uses the PTC heater...
This can be confirmed both by looking at Leafspy and also listening to the front of the car where you'll notice the radiator fan does not run, (which
always runs when the heat pump is running) nor does the heat pump.
Another interesting fact is that reading through some of the service manual for the car this seems to be a dealer configurable option as to whether the heat pump is used for preheat or not, set with a diagnostic tool. In the US cars the heat pump does run for unplugged remote climate control but not for plugged in climate control...
I have 3.3kW charger and during winter, timer uses a percent or two while plugged in to mains 7kW charger.
Don't take any notice of that 2 percent drop. The Leaf never reports 99%, it only ever goes up to 98% while charging and then jumps instantly to 100% when charging ends. Likewise the instant remote climate control kicks in the reading drops to 98%. It doesn't mean you've immediately lost 2% of your range.
My car does this instant drop from 100% to 98% even though I have a 6kW charger. Also if the car is sitting plugged in at 100% complete, if you re-start charging using the app (which you can do, oddly, even if the car is fully charged...) it will immediately drop to 98%, charge for a few minutes then go back off again...
