I had always thought we were stuck with KERS 1-3 with no zero regen for coasting.
But a couple of weeks ago, Casper (on the Driving Efficiency thread) said:
It's great and I've tried it on a few runs (on quests for essentials), but has a few 'quirks and features' and is probably worth a thread of its own.
Firstly, if you try it on a downslope, the car won't allow gravity to accelerate you and will use friction brakes (doh!) to keep whatever speed you had at the top!
To avoid this, you need to turn off ACC at the top of hills, then you have to feather the throttle to avoid regen until you need/want it.
I wish we had flappy paddles to control regen, like wot Hyundais have. It would be a great after-market upgrade.
What does the panel think?
Pressing the 'Set' button at any speed between 3 and 20mph will set the ACC at 20."I'm sure you're aware, but in case not, you can get KERS 0 with full coasting by setting ACC to a low speed, eg 20mph and accelerating past that speed - if you then lift off the accelerator voila! - no regen at all.
ACC turns off if you hit the brakes but if you want to go for max efficiency on an open road, avoiding friction braking and regen braking is the ultimate method - just don't run up the arse of the truck you're drafting...."
