1 - 6 of 6 Posts
· Registered
Hi All.
I have a 72v system taken from a working vehicle. It is suited to a smaller vehicle (small hatchback or something like an old mini?).
It includes everything but batteries. You'll also likely need an adapter and coupler but I do have the originals and the gearbox if required.
Batteries can be sourced from indra.co.uk - happy to swap the charger for a brusa NLG513 if purchasing a higher voltage battery pack. I believe the controller will support up to 36 LiFePO4 cells - 120v.
I have absolutely everything required to convert a car but the batteries. Add 72v of lead (£1,200ish) or lithium (100ah~£3,000), a small car and more or less ready to go.
Contents:
-HPEVS AC31 motor - approx 120ftlbs to 2000rpm and 36hp.
-Adaptor plate and coupler to fit daihatsu move. I believe this also fits daewoo/chevy matiz and some opel/vauxhall gearboxes.
-Gearbox (if required)
-Motor mounts if required
-Curtis 1238 AC controller - 550amp, includes aluminium heatsink, about 3 inches thick.
-Brake pressure transducer (for controlling regen)
-Accelerator pedal (with built in signal box
-Delta q 12amp 72v charger
-Main contactor
-Pack fuse - 400 amp
-Heater (ceramic) and contactor
-Vacuum pump
-Vacuum switch
-Various HV cables, lots of terminal covers etc
-All LV ev related looms (and connectors!)
-Dash pinnacle (kept it as was quite smart! Shows SOC, rpm etc
I think that's all of it. Will post pictures tomorrow.
Happy to deliver in UK or ship overseas. Collection from Upton on Severn, Worcestershire is fine. Viewings welcome.
Asking £2,500
Cheers,
Mike
· Registered
You could but ut may be slightly slow as the new mini is a slightly heavy car
· Registered
Perfect!
· Registered
Just taken a look at the up! specs...
930kg which is suprisingly heavy. I'd probably consider a bigger motor for the up depending on your performance goals.
1 - 6 of 6 Posts
