1 - 11 of 11 Posts
So it appears that I'm getting condensation on the inside of both my tail lights. This has happened before but with just the passenger side tail light back in mid 2020. A mobile service came round to replace the light, which fixed the issue but now it's happening again, this time to both lights. I booked a mobile service but they're refusing to replace them and are claiming that it's perfectly normal and all cars have the same issue, which is a load of rubbish if you ask me. My partner's car doesn't have this issue, nor did any of the cars that I have previously owned.
Just wondering if anyone else is having this issue with their Model 3 and if you've also been fobbed off by Tesla. Did you manage to find a way around it or did you argue your case and how successful were you?
Can this cause long term damage to the lights?
140159
140160
My car is in the SC waiting for a new headlight for the same problem. They claim that a certain amount of misting is expected (why?) but if the droplets start to run they replace it. It appears to be a common problem and I assume it's down to poor quality control when the units are being manufactured. I'll attach some photos of my 4 week old car.
140196
140197
140198
140199
Condensation in headlights is common in a lot of cars that I’ve seen, VWs and Mercedes recently that I can remember.
Tail lights less so...
a relative took delivery of a 2021 Model 3 recently and nothing in the lights but B pillar cameras both blocked by condensation the whole first drive (about 90mins) and autopilot disabled accordingly... since then they have cleared but not sure what will happen on another drive - a while to wait to figure that out!!
Discussion Starter · #9 ·
I find it rather odd that they would say it's perfectly normal and within tolerance when clearly it's a fault caused by poor welding of the plastic as per the video. But it is what it is I suppose. I'll just do what the guy did in the video to seal up any holes, hopefully that will fix the problem.
The issue comes if it gets into the bulb connections. I was behind a performance a while ago that would have been under 7 months old, with a rear bulb that was blown. Tesla can call that a consumable, but to fail after 7 months would really bother me
1 - 11 of 11 Posts
