1 - 12 of 12 Posts
Hi all. I wonder if any of you guys know whether there is a problem connecting a calibrated taxi meter to the Kia Soul or indeed any EV ?
Usually a " pulse " is taken from the gearbox of the car to get a signal to the meter which in turn is calibrated to the local authority rate. As an EV doesn't have a conventional gearbox I'm curious as to whether a pulse is present or can be detected ?
The other worry is that fitting a meter could in some way nullify the warranty ?
I appreciate that EV's are being used as cabs but concerned that they may be using "fare calculators " rather than a traditional meter.
I'm going to call the local dealer tomorrow to try and get some answers but am feeling a bit anxious.
I have my heart set on the Soul and with overnight parking and charging now sorted I'm ready to commit to a nearly new on on HP rather than a lease deal.
Many thanks in advance. ...Tony.
2018 Soul EV
I would imagine Nissan would be the best ones to ask as lots of those have been used as taxis. Actually I think most if not all are being run as private hire vehicles. Do private hire require a meter?
Private hire in Brighton are required to use a meter by the council.
The 3 companies all run mixed fleets of Hackney carriage and P/H.
I will maybe give Premier cabs in Blackpool a ring later and ask if they use a meter .
Had a Soul EV on a 4 hour test drive on Tuesday. It done everything I wanted and more. What a fabulous vehicle. Up hills (extremely steep ones) with 4 passengers with no issues. Have had it confirmed that fitting a meter is not a problem and the nod from the council that the vehicle is suitable for licensing.
Now I just need to decide which one to get but am leaning towards the 2018 30kw.
Will update as and when I do.
2018 Soul EV
For reference you can count on 90ish miles in winter use. Around 110 in milder weather on a mix of A and B roads with a 27kw Soul. So the 30kw should give you about 10 miles extra. Glad you liked it so much.
Blackpool's First and only Electric Taxi Company!
Just hang fire for the moment ;)
Hi cabby7. I’ve been searching for many hours for a solution to the same problem you came upon a few years ago. My dad owns a cab company in Maryland and all fares have to be ran on the meter which reads time and distance from pulses. The problem occurring is that I fell in love with this Tesla model 3, but I’m running into the problem of not finding any answers anywhere of how to hook up a taxi meter to an electric car that likely doesn’t have a pulse reading/ transducer. I would sincerely appreciate it, if you could enlighten me with any solution you came acrossed.
Hi I came across this discussion while googling model 3's. I supply and fit taxi meters for a living, fitting EV's isn't really any different from diesel/petrol vehicles. Its getting rarer and rare to find a traditional pulse in any vehicle. A lot of the time a Canbus interface is required. I've done various Nissan Leaf models, a couple of Tesla Model s and a load of hybrids. An experienced taximeter fitter should be able to source interfaces and work out where they need to be wired to.
Discussion Starter #11
In the end the Soul didn't need a canbus interface.
The guys at radio relay tried several different ones , none of which worked and connected direct to the speedo .
Obviously hooking a meter to the car risks invalidating the warranty because it likely excludes use for hire. Whether the battery is excluded as well, I don't know.
1 - 12 of 12 Posts
