Hi
Thinking about getting the Corsa e with the 11 kw charger. The dealership is clueless about the car but the laminated sheet they handed me clearly states that the 11kw charger option will charge at 7 point something on a 7.4 charging unit supply. I have seen post speculating that the 11kw charging option on the car may only charge at 3.3 kw if a single phase supply.
Can anyone say for certain whether the 11kw option will in fact work at the usual stated charging speeds on single phase supplies?
Will usually be charging on 22 kw posts so want to be able to charge at 11 kw but also want to be able to use home charger at 7.4 kw.
