1 - 9 of 9 Posts
Hi just sorted my defer charging issues with my Ds3 Crossback Etense
App won’t work and nothing in the car to sort
I installed a 60amp Smart WiFi Meter and with App TuyaSmart Smart it controls the charging point and monitors the energy consumption and schedule of the charging on the car
Ds have been a nightmare on customer service
Emylo Smart WiFi Meter £35 from Amazon
2014 Model S
All the PSA cars are similar in that they charge immediately you plug them in. If you want to defer the charge and you have a smart charger it's better to plug it in and let the charger sort it out. If you try and defer the charge on the car then I think it gets confused.
There is a button in the charge flap that switches the car between immediate charge and deferred charge. It's got a clock time thing on it. If you unlock the car and open the flap and don't open the doors and the auto relock kicks in before you've plugged in the charge cable it might also change to timed charge on the car.
I assume there is something on the infotainment system with the timed charge settings.
It was ok when chargers were dumb but now they're smart the car and the charger can end up fighting over who is deciding when the car will charge.
It's worth looking at the user manual as it should say about what it does by default. It might need some experimentation to find a combination that car and charger are happy with.
Nothing on mine and no energy symbol for entering infozone
This is the only way I can defer charge
2014 Model S
It's definitely got the button for deferring the charge from the car.
If you plug it in and let it start charging and then use the smart charger app to stop the charge and then set a time on that app for another charge time what happens?
Like I said the app won’t work on my Car
Been told by Ds that it has a recall and software upgrade needs to be installed
No buttons just a blue light
I ain’t new to Electric Cars but my Vw software foolproof
Ds software needs a lot more work
I’ll admit there DS app needs a lot of work. But you can make it work. When you plug it in. On the page in your top pic you click charge and it goes to a screen with a button in the middle saying instant charge/deferred charge. It starts instant charging. Then you click the button to deferred charge and it stops saying charge interrupted and will start the deferred charge at the time you select just below the app. I think if you change time when it’s doing that charge it will stop then but I’m not sure. I have only managed to fully charge as I set mine for 00:01 for the cheaper rate. Why they don’t just have two separate start and stop times is a mystery. App sucks to be honest as does the hands free. In my last car a Ford, it was easy to call people by talking to it. May as well not bother trying in the DS
1 - 9 of 9 Posts
