1 - 4 of 4 Posts
My car is working itself! I now have off peak charging and have set the car up to charge between 00:45 & 04:00.
despite this when I plug the car in it starts charging immediately!
The app also shows it is set for Low Cost but the car is charging. I have been back into the car, checked the setting unplugged and re plugged the car and it is still charging immediately
last night when I plugged it in it started to charge straight away but then switched off. Tonight was different nothing I could do would stop the immediate charge.
i have just checked and the app is showing charging paused. what the !!!!
I'm struggling with this one too. We have a pod point and have the PHEV set to midnight on the timer, but it just always charges straight away. At the moment its just cheaper to run on petrol. I'm guessing it's an issue with pod point not having delayed timing built in?
What departure time have you set? If this is too early it will override the "favourable" charging times and start charging early or immediately. Also, as above, have you got more than 12% charge when plugging in?
1 - 4 of 4 Posts
