1 - 4 of 4 Posts
I got my new car 2 weeks ago, and have now found the tyre pressure info page, which I was surprised to see was showing 44-46 psi. So, I checked inside the door frame at the sticker and that says 36 psi. No wonder the car felt like it was on tip-toes and it had bad torque steer at full throttle.
So I put them down to 36 and will give it a test drive tomorrow.
So, if you have a new delivery. Check the pressures!
2021 Citroën ë-C4 Shine Plus
This is a common occurrence for cars arriving from Korea. Tyres are over-inflated for the voyage here to prevent flat spotting (or something), and often don’t get put back to the proper pressure at the port.
Definitely something the dealer who sells it should check
Yeah, as if ...
However, don't be surprised if you get a tire pressure warning that doesn't go away if you have it that low. If you do, increase the pressure to make the warning go away and then reduce it again.
Kia Soul EV 2020
I have bad news for OP, the bad torque steer is not going away. It might get better with the lower tyre pressures, but not by much.
Also, give it a test drive. And then give it some extra air. I find 39psi (cold tyres) works best for comfort, noise and efficiency. Just to be clear, mine is a Soul EV, but pretty much the same car, different badge.
1 - 4 of 4 Posts
