Welcome!I’m just a little ole biddy that has this great looking and performing vehicle that only charges in the heat. Sadly UK based so that could be a problem.
Picked up the Megane ETech pre Christmas.
If the temperature is above freezing the car charges on a remote set up. If it is below freezing it won’t do so and my husband ( little star) has to go out to set it up manually. So frustrating.Welcome!
And hopefully you are enjoying your new Megane, which is a lovely looking car I must say. Hopefully it has incorporated learnings from the Zoe, which is a fun little car, but not without its issues.
What do you mean about it only charging in the heat?
Wow. That's a new one on me! Hopefully it's just an app issue if the car can be charged manually, but still, that's an absolute pain to have to deal with in the winter.If the temperature is above freezing the car charges on a remote set up. If it is below freezing it won’t do so and my husband ( little star) has to go out to set it up manually. So frustrating.
I have a Vestel PEN charger installed by EON which we tested and tested countless times.Wow. That's a new one on me! Hopefully it's just an app issue if the car can be charged manually, but still, that's an absolute pain to have to deal with in the winter.
I think you need to raise that as a fault with Vestel, it isn't normal and isn't acceptable, they need to sort it out.I have a Vestel PEN charger installed by EON which we tested and tested countless times.
It is correctly earthed and works except when the temp is minus. The car has the lovely red rectangle of death when not playing.
I asked the CIA if I could borrow one of their satellitesHow did you get a picture of her charger?
BTW mine charges below freezing as do all those sold in places like Finland where you know it's below freezing without checking.
The chargepoint is going to be the suspect but it certainly sounds very very odd.
Gaz
Sweet!I asked the CIA if I could borrow one of their satellites![]()
Sweet!
I had them spend 26000$ checking if you could see my bald spot from space once.
Tech is a marvelous thing.
Gaz
[/QUOTE
