1 - 15 of 15 Posts
Can you guys help me, when you get to 0% and zero on the range well three flashing dots, how far can you go till it stops im in a 2013 tekna, someone said he got ten miles sounds far fetched
Never got to Zero as it seems to cut off at 7%.
Ivve had one flatbed and would say i got no more that 5 miles from when it went blank.
Mine seems to be about 9% 9 miles it goes off
Guess I should just see when ive time to waste, will put my generator in boot then can go for it.
still not used that cable not had any idiots blocking bays yet
I have seen that before ,has it been done in a gen 2
EV and renewables specialist
I once ran approx 10 miles after the range indicator went off without reaching turtle mode to make last few miles home.
Banned
I have achieved 101 miles with 6miles on 0% battery and no range.
However, last Thursday the cold temperature, rain and high winds reduced overall range to 71 miles. Range & bettery % both went from 8 to zero in a flash at 61 miles. Managed 10 more desperate miles before I stopped with 2 to go!!!!
Nissan arranged return to base eventually on a flat bed but first the recovery guys turned up with jump leads!!!!
Our drivers are masters at running out cars. Usually about 1/2 mile from the charger! We find that when the miles and percentage disappear (---) which is at 6% or 7% we only have 3 or 4 miles to completely flat. Don't trust turtle mode because we had a car do 1.3 miles on turtle and another do 400 yards.
I agree @Michelle C&C, there can be huge variation.
Our LEAF fleet has only needed two recoveries - both my fault as I was pushing the envelope. On the first I stopped before the car did, having gone about 4 or 5 miles in Turtle, while on the second occasion I just coasted to a halt on the Edinburgh City Bypass seconds after the Turtle appeared.
Yes, both of these instances were in a Gen 2.
Reactions: Paul
Range at the bottom end is hard to predict because:
  1. The computer does not know exactly how much is left; it makes a rough calculation from the voltage, temperature, health and history of the battery.
  2. Turtle will kick in when the weakest cell pair hits the minimum allowed voltage, around 3.0. So a battery with well-matched cells should go further than one with a poorly cell.
  3. As always, range for a given amount of juice depends on speed, temperature, gradients etc.
Interesting.
Just had two turtles in a day on the 24th. One trivial at the services countdown markers and the other a bit further out. Didn't measure distance, but I think it was slightly downhill, as still 3 gids at the charger and no real sense of speed loss despite only one power bar available (I'd found a truck doing a Leaf indicated 56/57 to help me limp in)
I was wondering how good for the battery this is though. I've seen generic li-ion info saying not so good to run below true 20%. Looks like a leaf pack is still around 10% SOC when flat (or at least 10%SOC by leaf spy..). Gut feel: if it was really bad it would cut our earlier...
Good to see that the C&C "test programme" includes regular (?) runs to flat with no major issues!
1 - 15 of 15 Posts
