1 - 14 of 14 Posts
· Registered
We have just bought an ex british gas van to convert into a mini camper and after stripping the interior rack we noticed a diesel tank?!?
Looking under the bonnet the second pic is the best guess as to what it connects to?!?!
What does it do?
Thanks in advance
· Registered
ooh fancy
shame about its placement, that is going to cause problems with a rock and roll bed
Is that a filler cap on the top right? If so, it may be a separate fuel tank for the heater so could probably be relocated but the feed to the heater will be by gravity. of course you could just remove the tank and not use the heater,
· Registered
It looks like the fuel tank is a long way from the Webasto heater, so I doubt if the feed is gravity. However, if it is gravity-fed, and you want to retain the heater but relocate the fuel tank, a 12v pump is readily available:
The British Gas E-NV200 fleet was mothballed in 2015:
Has the battery in your van degraded?
· Registered
Discussion Starter · #12 ·
How do I check sorry?
· Registered
Have you already tried to use the diesel-fuelled heater? I believe it is recommended that both petrol and diesel Webasto-type heaters should be fired up once a month. As your van may have been in long-term storage, I would suggest first confirming that this heater is functional.
Forum member cyclingaviator suggested that these heaters usually do have an internal fuel pump, since when fitted to a non-EV they draw fuel from the vehicle's main tank, which would be under the floor, rather than mounted up on a bulkhead.
You may be able to confirm the action of the pump by temporarily detaching the fuel tank from the bulkhead and lowering it to below the level of the main Webasto heater unit, whilst running the heater.
Alternatively, put some fuel in a glass jar and connect it to the heater inlet using transparent plastic pipe, so you can observe the flow.
· Registered
The diesel heaters have a "dosing pump" they never run as a gravity feed. It'll make a ticking noise as it's an electromagnet type pump. Make sure to have the van switched on as the heater will draw quite a lot of current on startup as it has glow plugs just like a Diesel engine.
These were fitted to the British Gas vans as the e-NV200 has a resistive cabin heater that uses a lot of energy from the motive battery, and British Gas wanted to get the most range from the vans in winter.
I did consider fitting a diesel heater to my e-NV200 24kWh van for the same reason.
1 - 14 of 14 Posts
