Finally got round to doing this after 8 months with two EVs and only one charge point. The ChargeMaster is 4 years old. Ohme installed a couple of days ago. Charged both cars last night and no sign of the house exploding so that's all good...
Alas, exploding houses seldom give any warning !Charged both cars last night and no sign of the house exploding so that's all good...![]()
This was all properly done, the DNO and installer etc all know two points fitted. 100A main fuse of course. We could still blow that if we deliberately tried ... all kitchen appliances on, 3x elec heaters, heated floors, 2 EVs plus a 9kW electric shower would be > 120A. So I won't try thatWe're the same, have had two charge points for a few years now. We pretty much always charge the cars overnight, at the cheap rate, and have had both on charge at the same time once or twice. It's no big deal, really, and frankly I think that 99% of the fuss made about it is from installers who can't be arsed to take the time to assess the actual max demand at the house.
FWIW, if anyone does have a marginal situation, with regard to maximum demand, it's very easy to just total load limit, either using one of the charge points that has this, or by just fitting a priority relay in the connection box. The latter is a dead easy fix that doesn't cost a great deal of money, and works even with dumb charge points (or smart ones that go dumb because the tech driving them falls over).
I'll be doing the same when we get a 2nd EV (already have a podpoint + Ohme with Commando socket in the garage)
Did you have to have an earth rod for the Ohme?
That's rather expensive, and I'm not sure they do a type 2 variant.Anybody mentioned this one? HCS-D40 Dual Charging Station| Level 2 | ClipperCreek
And it looks to share the 32Amp, which isn't ideal if trying to charge overnight on 'cheap fuel'That's rather expensive, and I'm not sure they do a type 2 variant.
Earth rod was quoted but not required, so I was refunded the cost of it. So no, is the answer....
You won't blow the fuse. The minimum current that appears on the graph for a 100A BS88 fuse is 150A and it will hold that for 7,000 seconds (2 hours). One reason for not trying it is that drawing 120A for two hours would be expensive!This was all properly done, the DNO and installer etc all know two points fitted. 100A main fuse of course. We could still blow that if we deliberately tried ... all kitchen appliances on, 3x elec heaters, heated floors, 2 EVs plus a 9kW electric shower would be > 120A. So I won't try that![]()
I assume from the instructions that the OHME has no internal Open PEN protection so you can understand why they have made their lives easier by mandating TT. However, in doing so, they haven't addressed the risk of inadequate separation.That's wrong. The requirement in BS7671:2018, Amendment 1 (to Section 722) does not require that the installation be TT, and there is no mandatory requirement to install an earth electrode and make the installation TT.
Reassuring! But I still won't try to blow itYou won't blow the fuse. The minimum current that appears on the graph for a 100A BS88 fuse is 150A and it will hold that for 7,000 seconds (2 hours). One reason for not trying it is that drawing 120A for two hours would be expensive!
TBH, I think they just haven't bothered to update those instructions for a year or so, at least since Amendment 1 was released. That amendment clarified the use of devices that monitored voltage as a way of detecting an open PEN fault (not that I think that's particularly safe).I assume from the instructions that the OHME has no internal Open PEN protection so you can understand why they have made their lives easier by mandating TT. However, in doing so, they haven't addressed the risk of inadequate separation.
Is there any reason you can't get a 30A outdoor socket installed and obtain a suitable lead.
I was surprised and pleased to discover that the EVSE supplied with the eTron includes an interchangeable 32A Commando tail and supports charging at 32A from a suitable socket. Interchangeable 13A tail also supplied; it's the best manufacturer-supplied EVSE I've seen....to factor in the cost of a suitable portable EVSE that can handle 32 A (the Ohme can, as can the Tesla UMC, plus one or two others).
