I have been fighting my drivers window! I often want it cracked open a bit to help with demisting (the demist feature on the A/C works great but this doesn't use any battery power!) but when I press the window down button it goes immediately into auto down. So I then pull up the button and rather than stop it goes into auto up mode - AAAGH! :x
I have been trying to find a way to tame the window and now I think I have found it...
Yet another gem from gm-volt.com...
http://gm-volt.com/forum/showthread...cret-or-magic-required-with-the-window-switch
Basically, the answer is simple and probably obvious to a lot of you already:
Simply press the "down" button twice. The second press stops the window instead of starting it back up again!
