No and you won't have a spare wheel either. They expect you to fill a punctured tyre with that blancmange stuff, after which no tyre firm will repair it. Get yourself a space saver wheel as supplied with some Golfs, Caddies, Audi A3 etc. I bought mine complete with jack and brace on ebay for £25. It was almost unused. Get the plastic screw thing to hold the wheel down from a Seat place (£10). Somewhere on this Forum I posted details. You can also do a Rolls Royce job at considerable cost - see the link I posted to another (I think USA) forum which gives chapter and verse.Hi - bought an e-Golf last November and have just checked and there is no jack and wheelbrace, do VW normally include these on an e-Golf?
Hi James - thanks for the reply. I'll check out the spacesaver.No and you won't have a spare wheel either. They expect you to fill a punctured tyre with that blancmange stuff, after which no tyre firm will repair it. Get yourself a space saver wheel as supplied with some Golfs, Caddies, Audi A3 etc. I bought mine complete with jack and brace on ebay for £25. It was almost unused. Get the plastic screw thing to hold the wheel down from a Seat place (£10). Somewhere on this Forum I posted details. You can also do a Rolls Royce job at considerable cost - see the link I posted to another (I think USA) forum which gives chapter and verse.
Hi Carty - thanks for the reply. I've never had to use the fluid (fingers crossed!) but will look at the Holts Tyre Weld.If you intend to keep with the inflation kit, use the Holts tyre weld instead.
It CAN be washed out after use and does not affect the tyre or the alloy wheel.
A bit less expensive to replace as well !.
The Holts cam is around £7 and the VW fluid is about £75 and it has a life cycle as well !.
It comes in two sizes, make sure you get the one that is suitable for 17 inch wheels.Hi Carty - thanks for the reply. I've never had to use the fluid (fingers crossed!) but will look at the Holts Tyre Weld.
Only the space under the floor. In my eGolf I have the wheel, jack, brace and tools plus a set of jump leads, the 13A charger, the type 2 cable (I've bought another to use in my garage), an extension lead and a waterproof thingy for the join and the little inflater. It's all a bit of a tight fit but it does fit and the boot floor sits properly on its supports..The down side is you lose a lot of space in your boot.
Hi Simon - thanks for the information and the pictures. I've been looking at doing something similar with an 18" space saver alloy kit.Just done this. You want the 18" space saver wheel, it's been the same across much of VW, Audi, Skoda for ages so easy to find. Mine was £60 delivered from ebay including the tool tray, jack, retaining screw, etc.
The problem is that cars that don't get a spare wheel have a trim piece that prevents it fitting:
Now you can buy the right trim (part number from a US video was 5G6 863 459 L 82V - my local dealer quoted about £45 to order one in), or just cut it a little to make it fit. I went for the latter, pull straight upwards surprisingly hard and it pops off, then a few mins of cutting and sanding got enough clearance for the tyre. View attachment 127731
e-Golf has the bracket in the floor for the threaded post, you just push in really hard and give it a quarter turn.
Still plenty of space for granny and 32a cables, plus any other emergency stuff you might need. The false floor still sits where it should too.
