I have mine at 40psi and the ride does not seem much different to 35psi (the pressure in the tyres when I took delivery in December). I am hoping that the higher pressures should help with the range.What is the ride like at 40psi?
I'm using about 39psi. It has always amused me that different tyre pressures are recommended for different load configurations etc. How the * do they expect anyone to be constantly varying the pressure. A compromise is the only answer. That said, you do need to add air as the temperature drops towards winter and let it out again in the spring. Also, I once drove from Holland to Switzerland and wondered why the ride was so harsh. Travelling in the opposite direction you end up on underinflated tyres. Dynamic pressure adjustment would be a handy gizmo.Now many drivers have had some months of experience what tyre pressures are being used and why? Do you change for different conditions, e.g. long runs at speed?
