pfffftttt ... can't even tell what doors/seats it has, let alone battery, who knows?!?!....What size battery do they have?
Yes, that is the one I got my CarWow quote for (9 seat Combi M) with metallic at £29,630. They don't actually do the passenger version with the larger battery, probably due to gross weight limits. The more expensive once is just posh, for the executive taxi market I guess?Just found this advert for one, which states a 9-seater for £31k, which largely fits with the original finance example posted in yhe op.
Vauxhall Vivaro e-Life Combi | Vivaro Life Edition | Drive Vauxhall
No it doesn't, it says 100kW which is correct. You definitely know the differenceThe advert I referred to clearly says 100kWh.
This thread is about the passenger version of the vans and as I explained there is no 75kWh version.I did about 1000miles as a test drive in the 75kWh battery version of the Dispatch
There is no need to be so aggressive, is there?No it doesn't, it says 100kW which is correct. You definitely know the difference![]()
I certainly wasn't intending to be aggressive and even included a wink, but you need to be able to take what you give 😄There is no need to be so aggressive, is there?
And merely to assert something which is wrong.
Good point and would warrant a complaint to ASA.It's just a pity that, as usual, the finance deal doesn't relate to the model shown - MWB poverty spec finance vs LWB relative luxury spec. picture in the advert.
