Rick... please don't misunderstand me... I am not saying they aren't helpful to some and I am not saying I won't ever use them either. If they help then that is great and now that you have a DIY EVSE it stands to help you even more as you can charge at the faster rate.
I am simply saying that commando sockets... in fact, any simple power sockets such as 13A, 16/32A commando... will not play a major role in public charging. There are less safeguards built in. You can easily kill yourself with an open socket. With a dedicated charge station that risk is much reduced as the power is not switched on until the circuit between the car and the station is confirmed by a data signal and if that data signal is broken the power switches off. It isn't a perfect system but in a public environment, particularly if it is uncontrolled, open sockets are not advised.
In controlled locations on private property then sure... commando is simple, cheap to install and reliable. I just don't see it playing much of a role in public access charging except occasionally for destination charging where there is no dedicated car charging station.
As for the DIY EVSE... my feelings on that are well known and I don't want to get into a discussion on that here (another thread perhaps
) but no... I won't be building my own. However, I have no issue at all with you or others building one if that is what you want to do. Providing you are all aware of the risks and if it works for you then fantastic!
As you say... we all have different needs.
