1 - 5 of 5 Posts
Hi everyone,
I am planning and have permission to install a home charger next to my parking space, i live in an apartment block, can and allowed to tap from the main consumer unit for the communal areas for the lighting etc, the qualified electrician i am planning to use has installed home chargers before but not sure how to get around to install an a "separate meter" to send me metered bills directly to me and not the management company. I'd appreciate your suggestions and advice if this is possible?
Well, I asked for a meter to be put in with my Rolec 5 years ago. Here's what I got, a mini-CU dangling off the main supply. Wires in from the left, grey wire to the right goes off to EVSE. I just read it monthly at same time as other meters & plot my data, but in your case someone would need to come & check your readings periodically.
140880
Hi everyone,
Are you talking about a meter that you can use to repay the management company for energy consumed or one to pay a supplier? The latter will require a separate MPAN etc. The other issue that you need to give a little thought to is what happens to the meter if you decide to move out. If it has a MPAN, then it will incur a standing charge even if it is not used.
I am talking about the energy consumed used through the charging point. I'm not aware of a separate MPAN. I would have thought, if i decide to move out i can simply get an electrician to put everything how it was? Thanks for the input anyway, it's worth mentioning this to the electrician.
As HandyAndy says above it is very straightforward - your electrician just needs to wire a meter between the EVSE (charge point) and it's electrical supply - something like this:
It needs to go in a waterproof box if installed out of doors, but again this is a very standard thing to do (I have one on my solar install).
1 - 5 of 5 Posts
