Q12 ignores home charging. If you charge at home then none of the options apply. Did you mean this to apply to away from home/workplace charging only?
Q17 needs some work. Whats the difference between an "issue" and a "problem" ? And the middle option "Neither a problem nor not a problem" is nonsensical.
Q17 also fails to distinguish between Tesla EV users and others. Tesla are a on a different planet when it comes to charger availability. My answer to this question would be radically different depending if i had a Tesla or not. Its also problematic what you mean by the "EV community" If i have a Tesla am i bothered that lowly Hyundai Kona users will find it problematic to charge at motorway service stations? Do i even know?
Q18 implies that there is currently no app that tells you where chargers are. But there are several already (and if you have a Tesla its built in as well but is it an "app"?. There should be an option "already use such an app/have that capability" .
However, bottom line is anyone who drives an EV would already tell you there is a demand for "improved electric vehicle charging infrastructure". No survey needed. I dont see how you'd get any quantitative data from your survey to add to that.
You dont (for example) ask;
Are there any trips you haven't made in an EV due to paucity of charging infrastructure along route?
Have you ever failed to obtain a charge and had to curtail a trip?
