Good chance the switch is faulty. If you have an OBDEleven or VAG-COM scan cable you can check the switch from the door control module. If you pull the switch and the state changes and you know the switch is working, but this is unlikely. I suspect just replacing the switch will be easy enough if you want to do it yourself or can be done by any competent mechanic or the main dealer.
