We had an interesting problem this morning. SWMBO took the ZOE out to go shopping, and after a couple of minutes she got an error along the lines of above. She also noticed that the battery wasn't fully charged despite having been plugged in overnight. She came back to swap to our PHEV and plugged it back in. The green light lit on the ChargeMaster point, but the car didn't charge.
I had a look around for anything obvious, but nothing came up. I check the 12V battery regularly, but I disconnected it and tested it again - health was 'good'. The thunderstorms forecast her came to nothing yesterday, so it's unlikely to be an electrical surge. I also did the old trick of turning the charge point off than back on again. Finally I took the ZOE for a drive to see if the error returned without luck, and after driving for 15 minutes, the range was 10 miles higher than when I set off.
I plugged it in when I got back, and everything seems to be normal ?? Any ideas what might have caused it? It's going for its 5th year service on Monday, so they might be able to have a look.
