61 - 70 of 70 Posts
Ex MY20 4 - MY21 4+ Due January
Discussion Starter · #61 ·
Don’t understand (I’m no electrician)
Haven’t seen a price for the Tesla unit but that output makes it a convincing alternative to a UK wall box... (we have a Zappi)
Was confused at relevance of adapter to power output - is it just a beefier adapter or is there something else going on...
Thinking I might buy one! Could certainly be useful travelling / visitng family etc...
The UMC allows upto 7kw.
You use different adapters, plugs with it and these limit the power it can take.
ie the 3 pin UK plug limits it to 10amp.
16amp commando plug 16amps
32amp commando plug 32amps....
So on and so forth.
It means you can buy the relevent plug for your need and none of this cheap euro adapter plug style work, They are much, much beefier for their intended purpose as well so wont melt like a cheap eu-uk adapter may well do
Discussion Starter · #63 ·
So on and so forth.
Need to Google Commando plug...
Discussion Starter · #65 ·
So on and so forth.
Struggling here(!) - so if plugging into UK domestic socket the limit is 10A?
So what if you go from UK 3 pin to a commando...?
...then the unit knows the difference and changes the charge rate accordingly. Not the only one that does this, Audi supply a similar device with the eTron for example. Comes with UK, Schuko and Commando plugs and changes the rate accordingly. Clever, innit?
Edit...or do you mean you made up a 3-pin to Commando adaptor...? Which is daft and would blow the supply fuse in the 3-pin plug 🤔
Renault Zoe 50
Don’t do that. The UMC will draw whatever it thinks it can due to the adaptor and blow the fuse.
Discussion Starter · #68 ·
...blow the fuse... That’s what I thought!
So a Tesla UMC is not going to supply any more from a UK 13A socket than the granny charger supplied with the vehicle...
Renault Zoe 50
Unless you plug it into a 16 or 32 Amp commando socket.
61 - 70 of 70 Posts
