Yes, they've discussed that on gm-volt.com. Apparently it's a safety feature: if the car is on then whenever the bonnet is open the ICE will run so that whoever is doing maintenance knows that everything is live.Dave Mathers said:I had the bonnet open and when I hit the start button the engine ran despite the battery being fully charged.I can only guess this is a maintenance function
As well on the 2011 & 2012 Volts there was no HOLD mode so if you had your oil changed then you needed to turn the ICE on ... and you did that by opening the hood/bonnet.Duncan said:Yes, they've discussed that on gm-volt.com. Apparently it's a safety feature: if the car is on then whenever the bonnet is open the ICE will run so that whoever is doing maintenance knows that everything is live.Dave Mathers said:I had the bonnet open and when I hit the start button the engine ran despite the battery being fully charged.I can only guess this is a maintenance function
