1 - 5 of 5 Posts
Hmmm. I'm stuck at an evolt charger. Type 2 locked into charger at charger e. No emergency.stopbutton. Can't get through to cps. Is there any way to force the charger to release?
Ioniq 38kwh 2020
try restarting the charge, turning car on and off etc, wiggle the chargeplug (sometimes if the plug goes in at a slight angle it has trouble releasing the locking mechanism)?
Hey thanks! Finally got through after 90 mins to cps. They ended up turning the charger on and off again, but no joy. Looks like I'm here for a while! At least it's a nice day! Thanks again
2017 Renault Zoe R90 Signature Nav
I’ve generally found that removing the charge cable from the car first indicates to the charger that charging has ended, the charger then unlocks the cable. How did you get on? I have heard of others having to drive away and leave the cable behind!
Thanks for asking!
We had to leave the cable behind in the end even though CPS did everything they could remotely. Still hopeful of getting it back as it's a 10 metre one and only a couple of months old. CPS indicated we should be able to arrange that with the manufacturer once they've liberated it.
I've sent a complaint to CPS along these lines:
1. Why did it take over 60 minutes to get through to an operator?
2. Why did the operators not have consistent knowledge of procedures? (The first two we spoke to said the manufacturer would call us and we spent over an hour sitting in the car waiting, but the third said we wouldn't hear anything until Monday)
3. Why does the charger not have a manual/emergency release?
In hindsight it could have been worse - we were able to charge on a tethered rapid nearby so we weren't totally stranded.
1 - 5 of 5 Posts
