What is there stopping you using a extension cable not a 13amp one i mean say a 32 amp
can you get them ??
can you get them ??
I've used a 10m 32A extension many times without problem. I use "commando" plugs/sockets rated for the continuous load and 6mm HO7 rubber cable. This is the standard equipment used on sound stages, outside broadcasts, etc., and is so perfectly safe if assembled correctly and checked on a regular basis.What is there stopping you using a extension cable not a 13amp one i mean say a 32 amp
You can order custom extension cables from Essential Suppliescan you get them ??
