Just discovered that you can fold the back seats even further and unlock even more space!
No need for any tools at all. Fold both seats forward as normal then starting with the longer seat back, if you look down at the hinge point you will see it fits in a slot. Pull the seat back upwards out of the slot then slide it towards you a bit so the other end of it slides out of the spigot that holds it linked to the other seat back. You can't remove the seat back completely because the 3rd seat belt is integral to the back and also fixed to the seat portion, but just fold it forwards and put it upside down on the floor in front of the seat. Same on the other side but it's even easier because there is no seat belt in the way. Make sure the metal spigot aligns and goes back in the hole in the long seat to keep it all secure and tidy when you put the short seat back on the floor. Recovery is the reverse, making sure you start with the short seat back first.
