1 - 4 of 4 Posts
Hi all,
I recently charged the misses 2019 leaf for the first time using a 50kwh charger (pb pulse). We had 34% charge when we started and it took 90 mins to get to 98%. Is this normal?
I'm well aware charge speeds decrease as you get closer to capacity and as the battery warm up but 90 mins feels like a long time to provide 25kw.
I would be interested in hearing your quick charge times
Cheers
NISSAN LEAF 62Kwh -
A warm welcome to the forum.
In my experience with both the 40 and 62 LEAF, is that on a decent charger, it will charge from 20% SOC to 92% SOC in 45 minutes. I have done this many times on Ecotricity charger and Instavolt plus many others.
However I have always had a warm battery, say 20°c minimum, If the battery is cold, then the charge rate is reduced to protect battery cells. It also does the same if the battery is too hot (Rapid gate),
Even if your battery was cold, say 8°c it would be slower, but no way would it take 90 minutes, especially as you started with 34% SOC. (I would expect it to take 30 minutes to get to 92% SOC)
I hope you do not mind me saying, but the problem is that you charged to 98% SOC which is really a no no on a rapid charger. Once you get to 92% SOC the charge rate effectively drops to 7Kw's (the same as an home chargers) at 96% SOC it really cuts the charge rate right down to 2Kw's and prepares for balancing which takes forever to complete.
So my advice is never charge above 92% and your rapid charge should never take more than 45 minutes.
My Leaf charges by 25kw in 4 hours at 6.6kw so 90mins for 25kw on a 50kw chademo charger is very slow.
Next time, see how long it takes to get to 90% when you will find charging will slow down dramatically.
At 6.6kw mine charges at full speed to 95% and then takes over an hour to get to 100%, so I normally just charge from about 30 to 75% unless going on a long journey.
1 - 4 of 4 Posts
