1 - 11 of 11 Posts
I’m typing this post out whilst sitting at one of the superchargers, looks like my home charger has a fault, there’s power to it but not charging, good job I woke up for a quick pee, thought I check my state of charge and realised it wasn’t charging!! I’m schedule to goto Birmingham today.
Who do I call for charger fault, the company who fitted my charger 5 years ago no longer in business.
If it's connected to wifi call the makers. They can see the fault, might be able to do something online.
It is not unknown for cables to fail with the years of plugging / unplugging. If the unit is tethered then an electrician could check continuity. for un-tethered just try a new cable.
Depends on the make, Rolec have standard parts, see various threads. The Chargemasters can have faulty main boards, there is a guy on here can fix them.
At 5 years the makers will only try and sell a new one and as the wiring regs have changed you may need more than just the box.
Tesla, its back to Tesla.
All good advice above. What make / model of charge point is it, does it display any behaviour, and tethered/untethered?
Reactions: kin
Thank you guys!! I am embarrassed to tell you all that my charger is working after all.
I powered off and on my ABL(Ironman) untethered charger this morning, and I also unplug/plug the cable. I am using Tesla model3 own cable which is only a year old.
Just came back home and I thought I'll give it another go and it charges!! :confused:
Maybe a soft reset on my Model 3 could have resolved the issue? I was kind of panicking this morning when I realized my car wasn't charged :eek:
I could have taken advantage of my Octopus 5p rate last night but ended up paying nearly £10 supercharger rate, oh well......
Discussion Starter #8 (Edited)
OK, tried out my neighbour's home charger with my own cable, still no charge.
I plug in my granny charger, it worked, sounds like it could be my cable then?
Very possible, try wriggling the cable near a connector end if charging starts you have found the break!
This will be a standard type 2 cable - you can't borrow the neighbors cable can you? assuming they have a type 2 car (most are now)
Discussion Starter #10
Nah, my neighbour's cable is type1.
I am going to Stockport Tesla tomorrow, they should be able to test my cable?
Discussion Starter #11 (Edited)
Wahey! Tried your method this morning, wriggled at each end of the plug at first, nothing, then I wriggle the whole cable, and it started to charge!
Went to Tesla, they confirmed it was my cable and replaced it with a 7m cable(I could do with extra length there!) While I was at Tesla, they informed me that there was a recall on my model(which I didn't know about?), something to do with relocating the electrical harness to prevent them from being in contact with water.
1 - 11 of 11 Posts
